Color section view 2
altnickee
61
Hi ,
I have made a section view of a part, and I want to color the face of the section to show the section-cut more clearly.
How to do this?
Toolmaker
The Section View is only a "display" with features that can not be edited. In order to do what you desire, you will have to create a Cut-extrude feature in your assembly. After this, you can select faces and change to colors of the cut components.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of Eng-Tips Forums?
ctopher/MadMango
Right-click on the surface, change color doesn’t work, so I made a Cut-extrude feature of my assembly. After this I tried to change to colors of the cut components, no problem changing the color of the parts in the assembly, but what I want to do,is to color the face that is left after the section- cut, not the complete part.
Toolmaker
RMB on the surface, select Face > Appearance > Color doesn't work for you?
[cheers]
...or select the new Cut feature in the assembly tree and change the color properties for that.
CorBlimeyLimey,
Your tip did the job!!!
thanks.
Toolmaker
Thank you for the "thanks" ... but my post wasn't a tip. Both Ctopher and MadMango had suggested the correct method to do what you needed. My post was just questioning whether you had tried their suggestion correctly.
[cheers]
... and MadMango's second post is actually the simplest way to set the face colour.
[cheers]
CBL, thanks for the chivalry. I remember submitting a enhancement request back in SW01 and SW05 to make the cut-face colors able to change in a Section View. It must be fairly low on priorities. Has nothing changed with SW08?
