MJC6125
- Apr 9, 2017
- 120
In the past I have typically detailed load bearing CFS joists to be attached to CFS studs either through a platform framed bearing connection or by running the joists into the wall cavity and screwing them directly to the side of the wall studs. I have used a track attached to the wall studs like a ledger sometimes, but I have always introduced some additional clip angles to fasten the webs of the joists to the webs of the ledger track. I assume this is still required sometimes based on loading. However, I'm wondering if people omit the clip angle all together sometimes and just rely on the joist to track to wall stud connection similar to how out of plane wind loads are transferred out of wall studs at bottom and top tracks. See image below for reference. Do people try to get these ledger track conditions to work for floor and roof framing with no clip angles?
The reason it seems weird to me is because with wood framing, I always introduce joist hangers at ledgers, but never worry too much about a joist hanger or connector at the top and bottom of wall studs. I was thinking cold formed might be something similar. Do a connector piece for joists, but for wall studs the track connection and those screws are typically sufficient. However, if I input the CFS joists as a wall stud design in the Simpson CFS Designer software, and input the full gravity loads. I'm finding that a track connection seems to work for quite a bit of load. See additional image below. Is there anything I'm missing that makes the design of this detail different for a joist vs a wall stud?
