Is it true that a coil spring will rotate abouts its vertical axis when it is deflected in the vertical direction?
I have a coil over shock absorber arrangement (like ones seen on rear suspension mountain bikes) and I am wanting to try qauntify the amount of rotation the spring will have during operation. I will then be able to somewhat estimate the amount of friction between the spring and damper to determine whether or not fitting a needle bearing will be necessary.
If anyone knows equations or methods of how this can be done it would be very much appreciated.
Cheers
Cheers
