Coil-overs are typically mounted straight up for straight line performance,e.g., Pro-street, drag strip. What are the guidelines for mounting coil-over shocks for handling through the curves? From researching various enthusiasts boards I have found angles recommended from 7 to over 30 degrees. I have also found various methods recommended for determining the best angle, however when applying the different methods I come up with greatly different coil-over mounting angles. Granted there are location and packaging restraints, but is there rule of thumb or optimal angle to shoot for?
