I need to specify an insulation system for stainless steel pipes. In the past AISI 316 has been used but after some years in service, severe SCC has occured. I have specified the use of either SAF 2205 or 904L as suitable alternatives that are resistant to SCC. The pipes carry water at 85C and the Cl- level is 35ppm. It is clear that SCC is originating from the inside and the outside of the pipes ie I have found both failure modes from metallographic examination. The question is how do you insulate the pipes without providing a water trap for Cl- containing water between the pipe and insulation. Would SAF 2205 resist SCC and other forms of corrosion under this condition. Should the SAF2205 be coated with some kind of paint, if so what about the inevitable scratch on the surface which will remove the paint? I have done some reading about paints and insulation systems and it seems the choice is VAST! Are there any tried and tested answers that can provide certain results?
Thanks so much!
180
Thanks so much!
180
