CNC Foam Model Capabilites in Vancouver BC area. 1
overkill4
152
Hi All,
I'm looking for a CNC machine capable of making a 14' boat model out of High Density Foam.
Anybody know of any manufacturers or shops that could handle this job?
60% of the time, it works every time.
Check with AXYZ automation, they are a Canadian company that makes cnc routers. They can sell you one, or point you to one of their customers, who can do the job for you.
B.E.
You can waste a lot of time and money looking for a machine that big.
Last time I had to make a sizeable foam model (about 200 cm x 50 cm), I modelled it in sections, complete with matching dowel pin holes for each section. Once joined, glued, filled, and painted, it looked fine.
Like I said I don't have access to the model as of yet, so the only dimension I'm positive about is the Max length of 14'
Thanks for the links!
overkill4
Based on that, composite pros suggestion of sounds like your best bet, they can do your model in one piece. whenever you get it sent to you.
B.E.
