Mila2015
- Oct 11, 2019
- 28
I have a situation where a client has a 480v, GE WPH Tie circuit breaker that needs to be manually closed. I didn't see sync checking in it's closing circuit, so I know there is no automatic voltage and Phase angle check, but the 500KV feeding network should be the same, and both units should have the same set-up (XFMRs, SWGRs....etc). Can breaker be closed with buses energized? I would assume we would be to verify XFMR taps are the same, and voltages are close...anything else?
