aktill
- Jun 8, 2004
- 7
Hi folks,
I'm working on a de-icing system for a northern Alberta river intake. Basically it has to ensure that a series of fish screens in the intake structure remain clear during the danger periods for frazil ice accumulation (just after spring thaw and just prior to fall freeze-up from what I understand).
Since Alberta Environment is insisting that these screens be mounted flush with the outer wall of the intake chamber, I have nightmares of not being able to pull them up if they freeze!
As a result, I'm hoping to run a hot water flush system to the screens, which would ideally thaw them out (connected to a portable boiler of some description). I was thinking that a header running along the tops of the screens could feed a series of spray nozzles with enough potenency to have warm water reach the bottom of the screen.
The big problem I'm facing right now is nozzle selection - is this even a feasible application? Since the incoming water will be just above freezing, it will take a fair amount of hot water to make much of an impact on the screen temperature.
The screens are about 3m x 2m, and the worst case scenario for flow through intake pathways is 1400m3/hr per screen. We could ask the operators to reduce this for the couple of weeks in question, in hopes of being able to keep the screens clear.
Any help immensely appreciated - there's not much out there on combatting frazil ice.
