Clearance holes diameter
APH
79
I need to know what the clearance hole size is for screws that is arranged in 3 by 3 matrix. Is there something like this on machinery handbook?
thanks
APH
What to you mean by a 3 x 3 matrix? Clearance holes for screws are usualy 1/32" larger than the screw.
Haggis,
I meant I have 9 screws in 3 rows and 3 colums. I'm afraid that the hole clearance for each screw is not big enough If I use 1/32" x OD of the screw.
Hope this'll be a little more clearer..
APH
You mean that you've got a couple of parts that are being screwed together, and you want to make sure that the screws going into holes in part (a) have clearance to pass through holes in part (b), considering tolerances, etc?
Hole clearance is one thing. Positional tolerances between your prime 9 holes and your 9 secondary holes are the issue, coupled with what acceptance/rejection level you are willing to live with during inspection.
Ray Reynolds
"Computers in the future may weigh no more than 1.5 tons."
Popular Mechanics, forecasting the relentless march of science, 1949
Have you read faq731-376 to make the best use of Eng-Tips Forums?
Ivymike,
You got it. That's what I want. I thought we have something like that in the machinery handbook?
thank
APH
If you can hold .007 true position
of the holes 1/64 clearance would
be acceptable. If you need .015
true position, then use the 1/32
clearance holes. The smaller holes
create stonger parts but greater
accuracy is needed.
Diamond,
Would this depend on the size of the screw also?
APH
