cleaning of a carbon disulphide process tube - what can i use?
sunshine419
Materials
Aug 7, 2008
32
Please kindly advise on how best possible to clean a carbon disulphide process tube which usually leaves a carbon-chromium mixture deposit in the tube from the mixture of methane and sulphur at an operating temperature range of 600 to 800 degrees celcius in na reactiopn chamber.
My main nconcern is how keep the tube in optimum operation. Can reagents or chemicals be used and what type if so.
can mechanical or vacuum cleaning be employed as well? Please your advise and expertise will be highly appreciated. Thank you.
