Clarification-Help on Reverse Screw Seal
condesinc
On re-reading my post, I thought some clarification was in order. (Have also uploaded sketch):
Application: Threads on a rotating shaft, comprising "seal" or "excluder" in conjuction with the OD wall of stationary through sleeve or bore. These are inboard of a mechanical seal. Thread end and sleeve flush with inside of polycondensation PET reactor. Process material on one end of reactor about 80-160 centipoise, other end about 2000-3000 poise,with near vacuum (2mm Hg)and 300 deg C in reactor. Screw mainly to keep "drip" and pushed and tramp polymer, sliding down walls from above seal/shaft, and "rubbed around" from end of agitator, from ingressing along shaft (14"dia ) to front of mechanical seal housing. Appears that threads on sleeve rather than shaft easiest to achive for particular application. RPM is LOW...from 2 to 3 rpm.
Thanks!
Do you mean a "windback labbyrinth seal" or an excluder?
Your seal vendor should be able to design an excluder that is part of the mechanical seal.
Something like you are describing is relatively easy to incorporate into the seal design.
