civil 3D profiles
youngEIT
quick question on civil 3D profiles; i need to trim the existing and the proposed profile lines to the two points (at the beginning and end) where they intersect. but looks like civil 3D has them as 'embedded' objects, which i cannot even break or cut. the only thing i can do is change layer settings. also, any ideas how i can do the profile plot ONLY between those two points?
You can't edit the existing profile as it is dynamically linked to the surface and the alignment. The proposed profile is dynamically linked to the alignment, but you can edit it -- you should be able to click on it and edit it, which should bring up the edit profile tools. If your edits are in contravention with the assigned minima then you'll be out of luck. To display just sections of the profiles, create a new Profile View and edit the beginning and end stations.
thanks for the info; yes, i figured that out myself yesterday. a follow up question would be, if i want to create a profile view from the start to end of where my existing and proposed grounds intersect, is there a way to 'inquire' those intersection points in the drawing? right click>inquiry does not seem to work very well with snapping.
