Circular pattern at an angle?
electracomplex
Automotive
Hi Y'all,
I have a case where I need to create a circular pattern on a face which is 20° to the vector I want the feature on. In other words, I want to create a circular pattern of a feature but have that feature remain congruent to a vector which is not the axis of the circle.
How would I do this?
~Felicia H.
NX 8.5.3.3
 http://files.engineering.com/getfile.aspx?folder=baaff4c9-f03e-4e00-aacf-2ba1db2b4a3e&file=pattern_feature_compound_angle.prt
OK, I'm an idiot. Pattern > Along > Offset did exactly what I wanted with no need to select the 20° angle.
~Felicia H.
NX 8.5.3.3
To be honest, i did not understand how you wanted the results to be... :-)
Tomas
