circular curve fitting
swah2000
HK
As the coordinates of two tangent points are fixed by some constraints. I would like to fit a circular curves to joint them together. If begin radius say is 80m. How can I find the second radius which shown in attached file ?
 https://files.engineering.com/getfile.aspx?folder=9d747308-2902-48b1-8689-1f520d7db8f9&file=circularcurve.png
You don't seem to have fully defined all your constraints; is it supposed to be smooth curve? To what degree?
What was the rationale for picking 80?
TTFN (ta ta for now)
One method would be to use the Sine Rule and Cosine Rule:
Solving, as follows:
Doing it graphically in CAD is easier using the AutoCAD 'ARC' command with 'Continue' arc.
Knowing the end point of first arc (R1 = 80000), and knowing the PT (tangent point of the end of the second arc) 'ARC Continue' will continue a tangent arc from the PCC (compound curve point) to the PT, then use 'dimension' to obtain the drawn radius.
I also get R2 = 41772 using CAD.
