Vladpl
- Sep 5, 2005
- 25
Hi All
I am trying to design a circuit that will operate a power relay(30A). Mains voltage in AUS is 240V 50Hz. I have tried to design few circuits but none of them worked. Then I went to google and that didn't help me very much. My problem is that I haven't used timing circuits for a long time.
What I need is to rectify the mains and step it down with a resistor to be able to run a 110VDC relay. Also the circuit needs a time delay of about 220ms on turn on and 220ms+ on turnoff (RC timeing circuit). I was thinking of using a 100V zenor diode, and a BF337 transistor to do the switching.
Can someone please help me with this. I know that it is meant to be a simple circuit and to some of you it would be the easiest thing to design. It has been a while since I did anything like this since I work with transformers.
Thanks in advance.
Thanks in advance.
