hooverdale
Hello Everyone,
We have panel board used for commercial purpose with 100A 3Phase 440V main breaker Model GE TCD134100WL, size of main feeder is 30mm2 THHN.
Loads: Lighting and Outlet, Aircon, CCTV.
Power Supply : 440V, 3Phase, 4Wire
No voltage imbalance.230V single phase load used line to neutral.
During full operation, we measured a phase current of 50-65A and the main breaker becomes hot. I doubt if the breaker is overloaded if we only use 65% of its capacity?
The main feeder also getting warmer and it is rated at 115A.
We also measure 6A at neutral conductor (also 30mm2 THHN).
Any thoughts?
Thank you in advance.
Any thoughts?
