Choked flow for Vapor PSV Relief
gasoperations
MY
Guys I was going through an interesting thread on the subject:
thread1203-152033
It is still unclear if no details for the PSV is available, could the discharge piping be designed assuming max. back pressure ( P1 for tail piping ) as 10% of set pressure and exit pressure as atm.
If "no details" are available, how would one know what size of pipe to assume.
Good luck,
Latexman
I mean if details like make, model etc. are not available but max flow rate, set pressure and inlet & outlet size are available( so 10% max. back pressure is known ).
Sounds possible.
Good luck,
Latexman
