Choice Between Higher Steel Grade and Higher Wall Thickness 3
Chembloke99
Chemical
May 6, 2009
23
I would like to know from both technical and commercial point of view if I have to make a choice for a subsea pipeline between Higher Steel Grade and Higher Wall Thickness, which one I should go for?
For e.g. , for a 6" pipeline should I go for API 5L X- 52 Wall Thickness - 12.7 mm or
API 5L X 65 and Wall Thickness - 10.97 mm.
Many Thanks.
They both work and he has to decide which one is the cheaper solution. Since he hasn't built the line yet, nothing's changed.
"The problem isn't working out the equation,
its finding the answer to the real question." BigInch
