China ToolKit to rename component
Strange.
When i add this system variables the GC Toolkit works fine (except some company based settings that give problems when GC Toolkit is active. So i activate it only when i need to create a gear).
Using NX 8.0 and Teamcenter 8 on Windows 7 (64)
From NX9, you would need NX30624 (NX Greater China Toolkit) added to your license to be able to use it now.
You would have to get access to the source code for the libgctool.dll that is used, or write code from scratch.
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
