I am looking at some drawings of a chilled water system serving a bunch of data center CRAC units. There are a lot more CRAC units than I have shown on the attached sketch, but the gist is there.
I am confused because the supply piping is a complete loop all the way around and so is the return. If you follow the flow in my sketch. Water leaves the pumps and can go either right or left to get to the chillers. Water leaves the chillers and can go either right or left to get to the CRAC units. Finally, water leaves the CRAC units and can either right or left to get back to the pumps.
To borrow a line from This is Spinal Tap, "there's a fine line between stupid and cleaver." I am trying to figure out which this is. I regularly see complete loops like this on compressible systems, such as compressed air, to help equalize the pressure. But I have only seen it once before on a hydronic system, and it was a data center as well (coincidence???)
I'm trying to wrap my mind around the pros/cons of such a system. Is it something that you would recommend on a new system design? Seems like a lot of additional piping cost. What is the benefit?
