Suggestion to SteveKW (Electrical) Jul 9, 2003 marked ///\\If it is a DUAL voltage motor ... regardless of how you connect it ... high or low voltage ... the start winding ALWAYS sees low voltage!
///Assuming that this is correct, then\\A motor connected 110 volts has ALL of its windings ACROSS the line as opposed to having the motor 220 volts and the start windings in SERIES with one of the run windings.
///This means that the 110V start winding in series with one of the run winding has 110V and the run winding has 110V. Then, after the start is performed, the start winding will be turned off and the run windind 110V will be connected to 230V or will not?\\\
