Sidework
- Mar 3, 2011
- 1
Will moment capacity develop in a horizontal channel section that is attached to the exterior flange of a wide flange beam column? The Column is bent along the weak axis. The channel is bolted through the web to the column flange. The frame is loaded horizontally at the connection (seismic). The base of the column is considered pinned. I have attached a sketch with some other detail.
