Hi, i'm currently looking at a problematic gear train on a machine my company made. It's being used in a roll-forming application and the gear teeth are snapping clean off at the root of the tooth due to the fact it is under-designed (i did not design this).
Currently: 14.5 degree pressure angle and center distance between 2 gears changes a total of .133"
Some specs are being changed so that the center distance change is only .075".
I'm wanting to make the gears 20 degree pressure angle. I am also enlarging the face width as much as possible (dimensional limitations). Does anyone know how this will affect the backlash on the gears and any other important aspects of the operation?? the gears are operating at approximately 10 rpm.
Material change should not be a factor. Astralloy-v is being used and is doing better than 4340HTSR performed.
