Change model color in wf5
  • Thread starter Thread starter parbs
  • Start date Start date
P
parbs
Guest
Think this will be an easy one. PTC has not provided a menu maper for wf5 as of yet. How do you change the base color of a model to another one? Not sure where ptc move this option.
Edited by: parbs
as you've probably figured this out already, i'll just call it a courtesy reply.
click on the "appearance gallery" icon's dropdown (looks like a ball with a dropdown menu). it will bring up options for color, material, etc. by default, you will select surfaces. if you want to change the appearance for the whole part, just click on it in the model tree. all the way at the top, above the coordinate system, planes, etc.
hope this helps!
Hello.
which parameter in CONFIG.pro sets default "subject" (surface, part ...) for painting? l have set surface like default, but l will change it to part. Is it possible? thx you for answers
