chamfered edges and sheetmetal
  • Thread starter Thread starter wildfirebrigade
  • Start date Start date
W
wildfirebrigade
Guest
I found its impposible (in WF5) to create a sheetmetal part from a solid cube with intersecting chamfered edges. The only way I can get a flatstate from the part, is to extrude a big hole in the corner prior to converting to sheetmetal. See image:
Any suggestions for a proper solution??
<div menubottom="0" menuright="0" menutop="0" menuleft="0" activeid="-1" expanded="0" style="display: none;" id="divCleekiAttrib"></div><div menubottom="0" menuright="0" menutop="0" menuleft="0" activeid="-1" expanded="0" style="display: none;" id="divCleekiAttrib"></div>
Edited by: wildfirebrigade
If internal radius greater than zero, you can try to apply surface rip for corner and chamfer cylinder.
Thanks.
Anton.
In my experience, creating sheet metal parts from a solid shape is not the best way to go, because it doesn't give you the flexibility to add and remove walls that a wall by wall modelling approach will give you. However, your experience and design intent / changes may be different.
Given that, have you tried a conversion on the same shape without the chamfer feature. How about a draft feature or a couple of cuts? Is it a problem due to the geometry or the feature itself? (I am thinking it's a geometry problem, but you specifically mentioned a chamfer; so, I am wondering if you tried other features.)
^^^Agreed. I would start this as a sheet metal part, not try to make a solid model and then convert it over.
