asghar,
i highly recommend that you sondier hiring a skilled rotating equipment engr that will provide you the equipment that is needed.
as a minimum, defining the process fluid, process conditions, preparing specifications, and preparing data sheets is the first step in procuring a compressor.
yes, you can conduct preliminary sizing of compressor; however, the best and prudent decision is to allow the experts (manufacturers) design the compressor based on the stated process conditions. the mfg reps will gladly assist you with the preliminary sizing and selection; however, you or the responsible engineer must specify the process conditions to obtain the best equipment/solution.
based on pressure data you provided, td2k comments regarding intercooling are valid regardless of compressor type and this is a consideration for the mfg to know. what is more critical to know/specify is flow at stated temps and pressure for specified fluid.
bottom line recommendation, hire a skilled rotating equipment engr to handle the matter (there are plenty of them in houston). the skilled individual ought to be able to provide you preliminary and reasonably accurate results within a week or so.
oh, API 617 "...centrifugal compressors ..." spec is the std for specifying centrifugal compressors and the document and accompaning data sheets are not free. sorry! for purchase, try
good luck!
-pmover
