Dear All,
I would like your views on the start-up conditions of a compressor which operates under discharge pressure master controller (with override under low suction pressure).
Starting the compressor with its anti-surge valve initially open is mandated while bringing the speed to the minimum speed prior to the RUN state and loading the compressor via the performance controller automatically. However, I have seen that some studies consider the discharge valve initially opened initially, will this endanger the compressor to stonewall specially when speed increases.
Other start-up scenario, consider both suction and discharge valves closed in order to prevent the instability caused by reverse flow through the common suction manifold specially in the case of parallel trains operation and in absence of check valves at the suction. Is this start-up methodology practically followed?
Also, a general question,will stonewall operation be more prominent at high speeds or low speeds fora VSD machine?
