Justice100
Chemical
Hello all,
I have a 3 stage variable speed centrifugal compressor, compressing natural gas. The first stage has a recycle cooler and discharge cooler and the 2nd stage has a discharge cooler. The compressor discharges into a manifold fed from another set of compression trains.
I am trying to come up with a basis for sizing the recycle cooler. My thoughts were to simulate the compressor (with compressor curves included) at full recycle with the discharge pressure at the operating manifold pressure to replicate a start-up, where the speed is varied to achieve the discharge pressure. The remaining variable is then the recycle flowrate that I am now unsure how to choose. A recycle flow rate for the 1st stage, using the design flowrate would appear conservative as it should not be operated at design flow in recycle. Alternatively, a lower flowrate could be used with a good margin above the surge point.
Does anyone have an opinion on this or point me to a good reference?
