Centrifugal compressors want a pretty steady suction pressure and a pretty steady discharge pressure. That is because they'll only do about 2.5 compression ratios per stage. Consequently I don't recommend them for wellsite applications where I would have to hold significant backpressure on the well to maintain my assurance that the suction pressure remains in the design range.
When I say that in my classes, I often get the question "but you say that centrifugal machines are the most common compressors offshore, how are offshore wells different?" and my answer is that offshore wells have to be willing to accept a higher well-abandonment pressure to be able to have the energy density required by limited deck space offshore. That usually carries the day.
Today I was talking to a bunch of Engineers and the question came up again, and I gave my pat answer. One guy came back with "What happens if I just let the suction fall on a 4 stage centrifugal?". His machine is designed to go from 60 psig to 2000 psig across the skid. If the suction pressure dropped to 5 psig then instead of doing 27 compression ratios he'd need to do 117, and for a 4 stage that would be 3.3 ratios per stage which the machine just can't do.
Does anyone have a feel for how a centrifugal would look when it saw that sort of variability? Would it just stall out like a centrifugal pump, or would it go into surge?
David
David
