Centerlines needed or not? 3
kingsboy55
Aerospace
Dec 10, 2014
9
Hi, I would like to know if there is any definitive method for whether or not centerlines should be shown when using features of size.
The attached file shows a simple angle bracket with two slots in one leg, positioned using implied symmetry to datum A (the length of the bracket) and one slot in the other leg, similarly positioned to A. I sketched red centerlines in to represent the plane of datum A. Some would argue that the red centerline is meaningless and just adds clutter.
The same thing applies to the angle leg with one slot in it, should the centerline be shown through the 2" width of the leg or just locally through the width of the single slot?
We often have animated discussions about this type of stuff, for the record I want to omit the lines in red!
Thanks.
P. S. As an old guy myself I really enjoyed this thread about centerlines, I can so relate to making holes in paper, chisel points etc...thread1103-248576
Checkerhater,
No, and I thought of that after I posted. Centerlines of a feature (hole, slot, boss, etc) are ok to dimension to. The theoretical centerline of the part itself is not.
Ben Loosli
The theoretical centerlineplane of the part itself is not ok to dimension to if established as a datum plane.
CH -- why do you say there is no such thing as implied symmetry? Paragraph 1.4(k) of Y14.5 says there is, when something is controlled by a geo tolerance.
Perhaps you mean that there is no such thing as an implied tolerance on symmetrical features?
John-Paul Belanger
Geometric Learning Systems
Yes, symmetry as measurable control, as in "exactly how symmetrical?"
There is implied zero dimension, implied 90 degrees (both toleranced and basic), there is no implied symmetry.
CH -- there is indeed implied symmetry. You said so yourself: an implied zero dimension between two or more features that share a common, theoretical center; thus the zero dimension. That's symmetry.
But I see now that you meant a tolerance of symmetry (as in "exactly how symmetrical").
John-Paul Belanger
Think of it in terms of the person making the part. Is the CL the center of the part or the feature? If it's not clear, leave it off. If the line is needed for some reason, no harm to use it for clarification.
I still see people adding the CL symbol, making it more confusing.
Chris, CSWP
SolidWorks '16
ctophers home
SolidWorks Legion
