Centerline Control in the Drafting Package in NX2
MSawtell
Computer
Mar 2, 2007
134
Ladies and Gentlemen,
If want to place centerlines in a stamped metal part with a couple of semi-circle indentations in the Drafting Package in NX2 - how do go about it in the Insert - Symbol - Utility Symbols Menu? Then again, begin UG, is there another method/menu that can be leveraged?
MSawtell
What view orientation are you wanting to place these in? Is it an end view (the centerlines would show up as crosshairs) or a plan view (centerline would show as a line - the axis of the 'cylinder')?
Cowski,
Crosshairs on an arc - which I have muddled through - now I am banging my head on the A, B, C options for line length and spacing for the dimensions I am linking to the centerlines.
MSawtell
MSawtell,
Try making dim A=2.5, then B=5 and C=10 (for metric). Use smaller values but same ratio for English draings; i.e. A=X, B=2*A, C=2*B. That usually works OK for my drawings with Linear Centerlines (what you call crosshairs).
Tim Flater
Senior Designer
Enkei America, Inc.
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
