We have a couple rooms that have multiple pockets in the concrete structure as shown in the attached photo. We requested that the owner install a lay-in, tile ceiling in the room to avoid sprinklers in every pocket. The owner declined the ceiling stating that all the exceptions in NFPA 13 8.6.7.2 are met. This leaves us installing sprinklers under the narrow strip of concrete between the pockets.
This is a limited area sprinkler system supplied from a domestic water source. There simply isn't enough water available to provide a sprinkler in every pocket.
Sometimes I cant see the forest for the trees, and I miss the obvious, but this just doesn't seem right.
Thoughts?
Thoughts?
