I have a steam header that is failing every 1-2 years consistently. The steam is part of a cleaning system where 625# steam is blown into atmospheric pressure environemnt where the steam rapidly expands and cleans the carbon build up on the walls.
When not in use the system is closed off a dead leg exists at a highpoint. What I beleive is happening is liquid is condensing and falling back down the line, then flashing when it hits the superheated steam and causing cavitation erosion in the pipe. Is a stainless steel going to remove my problem (currently carbon steel), or will this constant caviation effect eat through stainless steel at a relatively similar rate? Is there any other alternatives?
