reallyme00
- Dec 11, 2006
- 13
Good day to everyone.
I appreciate if anyone can tell me the common causes for a Dry Gas seal failure in a Cryogenic Service.
A John Crane Type 28 VL is installed on a (newly commisioned )Ethylene pump.
Its a Vertical Turbine pump. Since the seal is a proven seal and it is running for almost 8 years without any problem on similar pumps in the same plant with same parameters.
We believe that the problem is not with the seal but with the operation. We have changed the seal twice and the Inspection report says that the symptoms are the seal face contact, which should not happen in dry gas seals.
So if anyone have previous experience in this kind of seal failure during commisioning , please kindly share with me.
Thanks a lot in advance.
