Sep 23, 2005 #1 par1 Automotive Joined Oct 11, 2004 Messages 134 Location US Catia v4 has option under curve 1 - intersection so you can create plane at any place in solid & get the curve line. Is similar opetion in Catia V5?
Sep 23, 2005 #2 silverunner Aerospace Joined Jul 7, 2004 Messages 31 Location CA Hello Par1, I don't know V4, but if I understand your question correctly, go into SGD workbench and extract the solid surfaces. Then, use the Intersection option to generate the curve. Upvote 0 Downvote
Sep 23, 2005 #3 itsmyjob Mechanical Joined Apr 11, 2002 Messages 2,375 Location CA Hi, you do not need to extract tsurfaces from the solid, just get the INTERSECT with the plan and the solid BODY. Eric N. indocti discant et ament meminisse periti Upvote 0 Downvote
