Catia v4+Curve 1-Intersection
par1
Automotive
Catia v4 has option under curve 1 - intersection so you can create plane at any place in solid & get the curve line.
Is similar opetion in Catia V5?
Hello Par1,
I don't know V4, but if I understand your question correctly, go into SGD workbench and extract the solid surfaces. Then, use the Intersection option to generate the curve.
you do not need to extract tsurfaces from the solid, just get the INTERSECT with the plan and the solid BODY.
Eric N.
