CATIA.SystemService.ExecuteScript problem
appvid
Automotive
Nov 9, 2012
81
Hello All
I'm trying to use below code to run CATVBS code from VBA. It throws an error that "Function or interface marked as restricted or function uses an automation type is not supported in VB"
Code:
Sub CATMain()
Dim EmptyPar()
Dim ScPath
Path = "C:\tmp"
CATIA.SystemService.ExecuteScript Path, catScriptLibraryTypeDirectory, "macro1.catvbs", "CATMain", EmptyPar
End Sub
☺- catScriptLibraryTypeDirectory is correct for catvbs????? or
do i need some settings to be changed.
regards
there is a typo , please read Dim Scpath as Dim Path .. sorry
(my CAD workstation is in different network from my mailing system. so can not copy paste my codes exactly. i have to retype all the code to post a thread in forum. :) )
Guys never mind I solved it.i used this
Code:
Call vSystemService.ExecuteScript("C:\Temp", catScriptLibraryTypeDirectory, "SetPartNumber.CATScript", "CATMain", params)
Hello fernando,
Iam still executing catvbs.
1) I did early binding on CATIA.SystemService then used "Call".
2) params empty ie. Dim Params ()
3) catScriptLibraryTypeDirectory is correct for catvbs and CATscript
Problem solved :)
regards
var
you are right. problem was with script line that calling catvbs..
