Problem exporting flat pattern (Composites Design) in DXF format.
T_M_S
Automotive
RU
Hi All,
I'm having a problem with exporting flat pattern (Composites Design) in DXF format. Thing is that everything worked fine but from some point it started exporting "empty" DXF file with no contour (annotations are still there). When I tried checking older parts/files where export was working properly, I found out that now it doesn't work and exports "empty" .dxf with no contour. If I export in .IGES - all works fine.
May be someone can suggest how can I fix this problem?
Thank you.
Ted
