Hello
I have created this macro to export Specification tree from catia to excel or text file format
but i am getting this error and i dont know how to correct it
here is the VBSCRIPT
Option Explicit
Sub CATMain()
'Launguage - VB SCRIPT
'Macro - Export Specification tree
'Declare Variables
Dim myDoc As Document
Dim myPart As Part
Dim partDoc As PartDocument
'Set Variables Values
Set myDoc = CATIA.ActiveDocument
Set myPart = CATIA.ActiveDocument.Part
Set partDoc = CATIA.ActiveDocument
'Export Script
Dim exportFormat As String
exportFormat = InputBox("Enter the format to export the tree as._ type 'xls' or 'txt'")
If exportFormat <> "xls" Then
If exportFormat <> "txt" Then
MsgBox "Did not enter the file format"
Else
Dim partName As String
partName = InputBox("Enter the name of the part")
Dim location As String
location = "D:\CatiaMacro"
partDoc.ExportData location & partName & "." & exportFormat, "txt"
End If
End If
End Sub
Here is the Error
Thanks in advance
Option Explicit
Sub CATMain()
'Declare Variables
Dim myPart As Part
'Export Script
Else
End If
End If
End Sub
Here is the Error
Thanks in advance
