CATALOG PROBLEM !!!! HURRY !!! ANSWER ME !!
Mxious
Hi
I've create a catalog of diferent Hss profils. When I insert instaciate part (part of catalog many times)
and I modify one of them all the part get modified ...
How I can break the link between the same part on catalog ???
Thank !!!!!!
Hello there.
Try to rename the profiles as you put them into the assembly, before putting in the next instance of the same profile.
-Bjod
When we instaniate parts from the catalog we try to always right click on the part in the catalog and then click on "Instantiate As New Component" to avoid the problem you have encountered. Hope this helps
forfun
