DAVIDSTECKER
I am looking for reference materials and/or pointers for a casting a steel part that incorporates a precast stainless steel component.
I have seen bronze gears cast around a steel hub.
The stainless steel would be shaped like a shell of the inside of a toroidal field (dough nut hole)
The steel would be cast around the stainless and become the structural support to be welded in place.
Stainless would most likely be ASTM A743 Gr. CF-8 and the steel A27 GR 70-36.
The stainless would weight maybe 300# and the steel 500-700#
In general most of the wall thickness' will be between 1-2" thick.
Thank you in advance for your input.
Best regards, David
Best regards, David
