friendlymonkey
Marine/Ocean
We’re looking to change to investment castings to replace components currently produced from plate that need fairly high strength and are subject to bending forces, we currently use Chinese HSLA plate with minimums of 690 MPa yield & 800 MPa UTS with about 15% elongation.
We produce varying sizes that have wall th from about 10 mm up to 30 mm, which want to be thru-hardened at least 1/3 to give good bending resistance.
In researching steels in the American standards domain we now have a short list of candidates
[ol 1]
[li]ASTM A487 grade 7-A (Cr-Mo-Ni-V)[/li]
[li]8630 as A732 grade 14Q (Cr-Mo-Ni)[/li]
[li]4130 as A732 grade 7Q (Cr-Mo)[/li]
[/ol]
All Q&T, temperatures suitable to achieve the above mechanical properties.
The steel needs to be welded to other casting(s) and is also hot dip galvanized (currently we bead blast, avoid pickling).
Foundry has already ok’ed the 8630 (14Q) and 4130 (7Q), but I’m particularly interested in the A487 7-A, because 1) its chemical composition is lower carbon than the others, and also closer to the wrought plate we’re already using, and 2) its minimum mechanical properties listed in the standard are identical to our requirement, while implying slightly better ductility than the 7Q and 14Q.
Unlike the others I can’t seem to find much about this steel despite trying to research it, and A487 doesn’t give any cross-referenced 4-digit AISI numbers unlike A732. The low carbon and vanadium doesn’t seem to match up to any that I looked at. Also, the standard annotates the 7-A grade as “Proprietary steel composition”, and I don’t understand the significance of that. The standard dates from 1963 according to its notes so perhaps it’s irrelevant now but I’d appreciate any insight?
I'm just looking for any pointers or info on this steel in particular, or any other comments are welcome.
[ol 1]
[/ol]
