As I don't do much casting/mold design, I am a bit curious about how people do this sort of work all the time.
From another discussion here, it seems that many actually design the 'as cast' part first and then use a configuration or insert part or assembly feature(s) to cut away material for the 'as machined' part.
As a designer, this process seems backwards to me. In my mindset, I would want to specify the end result (as machined)in my primary documentation. Tolerances should be specified that dictate what needs to be machined and where a rough cast is acceptable. The manufacturing experts then use the model and add material to allow for machining operations.
I do a lot of sheet metal work where we use the above design/manufacturing process. My drawing only contains the final, bent configuration with proper tolerancing. Manufacturing is responsible for how the raw material gets there (flat pattern, cut/punched/machined holes, etc.). Manufacturing may create their own drawing detailing their process, but that drawing model is based of the design model, not the other way around.
Thanks, Just curious...
