johntrhodes81
Automotive
Would anyone care to recommend a steel for casting parts that will be welded to SA-213-T11 seamless pressure pipe and have simmilar properties? This is for casting return bends on a locomotive superheater setup. The pressure is 310PSI and the maximum temperature is 850F. This temperature is a little hot for SA-178 boiler tube which should stay under 700-800F.
Thanks for the recommendations.
John R.
John R.
