Case Hardening and Carbon Content 1
metalman8357
Materials
Hi all,
I recently sent out samples of a competitors product to determine their material by ICP-AES. I was assuming that it was most likely AISI 1018 to 1024, but I was surprised when the results came back showing AISI 1026-1029. When the samples were sent out, the test agency was never told that these parts were carburized, and it's possible that a part of the case could have been tested with the sample. These parts are 0.186" in diamter with an effective case depth of 0.004-0.009". Personally speaking, I think that this could have skewed the carbon content higher on the test results. Anyone agree, or is the sequestered carbon from carburizing too small to explain this difference?
I think you guess right. Tell the lab next time.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
Your guess is right. An experienced lab, can definitely define the needs and accordingly draw the samples. However, this time reveal, that it is a case carburized steel grade.
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
I concur with the others. Almost certainly 1018-1024 rather than 1025-1029.
Provided the geometry and size of the sample allow it, I would think that it would be a fairly simply exercise to grind 0.010" off of the surface and re-test. That should give you your answer.
Maui
Elementary Dr Maui!, is what Sherlock Holmes would have said. A star to you Maui, I never thought of it.
Called the lab. Apparently they can run it at half mass by digesting the outside material with acid. We'll see what happens. Personally I like Maui's suggestion the most...
