I need some clarification on following:
The 'Air system sizing summary report' generated from Hap software defines different airflow rates in 'central cooling coil data'. They are
a)Coil L/s at month/time
b)Max Block L/s at month/time
c)Sum of peak zone l/s.
The 'Supply Fan sizing data' also gives two airflow rates
d)Actual max L/s at month/time
e)Standard L/s
I have a VAV system and none of the above generated airflow matches with the sum of individual space airflow rates.I have gone through the explanations/definitions of above mentioned airflow rates from Hap's help menu. I need to understand clearly what is the difference between each of them and which one to be used for equipment selection. For VAV system Hap says to use Coil L/s for equipment selection. Can anyone put some light on this?
e)Standard L/s
