aucklander
Hi all!
I created two identical models, one in version 4.2 and the other in 4.41 of the Carrier HAP software. After checking everything three times, I did not find any difference in the parameters values, but the latest version of the software generates higher cooling requirement than the old version.
What could cause this? Was there a shift in the overall design intent? A colleague of mine and myself designed the same system with the same parameters, and the boss selected the other design as more accurate (old software 4.2) as the cooling load is lower and consequently the required plant is more economic... I checked everything, we are using the same parameters, areas, surface, glazing, etc...
Your help will be appreciated.
