Carport Wind Load 3
nype
What is the wind uplift load on a free standing or attached one side only ( to a house) lightweight alumunum carport sturcture.
ASCE-7 shows uplift for enclosed and partially enclosed structures but implies there is only horizontal wind load on open (all sides) structure. Am I missing something?
oops- disregard above link.
Use this: thread507-75003
You aren't missing something, ASCE 7 is. Your options are to make an educated guess with your engineering judgment and the information you do have or find another code that addresses the problem.
The Australian Wind Code AS/NZS 1170.2 does cover this situation. Coefficients vary from +1.2 to - 1.5, depending on relative heights (canopy to bldg) and canopy width.
SacreBleu, thank you for listing thread507-75003. The problem I run into,is that the copy of ASCE-7 which I currently have,doesn't included coefficients for open structures with gable or hip roof systems. In case like that I usually use an old copy of the UBC. Fortunately for the open structures I design the magnitude of wind uplift doesn't impact the design very much.
