Cardan (cross) shaft bearings don't rotate in the usual way, and in fact, if the joint angle is too small, will not rotate at all. Makes it hard to identify a characteristic vibration.
You can instead identify cardan shaft defects that produce increased joint motion as the bearing rollers deteriorate. Should be a twice-per-revolution motion or acceleration at the support nearest the end of the shaft.
