Not a lot of salvation in that either. Again, assuming regular A106-B / A105 material, I calculate that 18" Sch 80 material is only rated to about 13,050 kPa (1893 psi) again with zero corrosion allowance (per B31.3).
Class 900 flanges would typically have a rating of 15,320 kPa (2220 psi)
Depending on the actual required design pressure, and the required corrosion allowance, the Sch 80 material may or may not be acceptable.
If you could let us know the following, I could tell you what schedule would be required:
- Design Pressure
- Corrosion Allowance
- Material (e.g., A105)
- Design Code in use (e.g., B31.3)
However, if you want full flange rating with a typical zero corrosion allowance, with A105 material then you would need a min of Sch 100, if you wanted a typical 1/16" corrosion allowance then you would need a minimum of Sch 120 (all per B31.3).
